SIP REGISTER fails after a few minutes spa122 with mynetfone
I have been battling with this for a while and realy appriciate some assistance.
I am having issues keeping my SIP regestration active, when I reboot my SPA122 SIP regestration is successful but after a few minutes the ISP (Mynetfone) sees my SIP connection as unregestered.
My setup is :
Modem - cisco 877
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
I think the following disables SIP ALG.
no ip nat service sip udp port 5060
My default Nat entry
ip nat inside source list 1 interface Dialer0 overload
Port Forwarding from my internal IP (SPA122) to my external IP Address.
ip nat inside source static udp 192.168.1.33 5060 xxx.xxx.xxx.xxx 5060 extendable
SPA 122 Config
Model: SPA122, LAN, 2 FXS
Hardware Version: 1.0.0
Firmware Version: 1.3.2 (014) May 9 2013
Line 1 config
NAT Mapping Enable: Yes
NAT Keep Alive Enable:  Yes
SIP Settings
SIP Transport:   UPD
SIP Port: 5060
EXT SIP Port: 5060
My SPA122 debug log
It seems ok according to the debug logs, when it deregesters I see nothing in the debug logs.
[0]<<125.213.160.81:5060(444)
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.33:5060;branch=z9hG4bK-395ceb2c;received=xxx.xxx.xxx.xxx;rport=5060
Contact: <sip:xxxxxxxxxxx@192.168.1.33:5060>;expires=120
To: "xxxxxxxxx"<sip:xxxxxxx@sip00.mynetfone.com.au>;tag=fc76a20-co8398-INS001
From: "xxxxxxx"<sip:xxxxxxx@sip00.mynetfone.com.au>;tag=726ed78aab0c40b9o0
Call-ID: d8c7ee9d-80ea5bd0@192.168.1.33
CSeq: 6235 REGISTER
Expires: 120
User-Agent: ENSR3.0.6
Content-Length: 0
[0]RegOK. NextReg in 395 (1)
CC_eventProc(), event: CC_EV_SIG_REGISTER_OK(0x3A), lid: 0, par: 0, par2: (nil)
AUD_ccEventProc: event 58 vid 0 par 0x0 par2 0x0
SLIC_stopRing
1 REPLY
Re: SIP REGISTER fails after a few minutes spa122 with mynetfone
I have finally got things working.
To isolate the problem the ISP suggested installing a softphone and try to register, this eliminates the spa122 from registering.
I installed X-Light, configured and it and it worked, so I then had a working modem Cisco 877 plus config and a phone config that works.
There was an issue with the spa122, hardware, firmware, config or a combination.
My plan was to update firmware if there was a new version available then factory reset the spa122.
I found 1.3.3(015) available so I updated the firmware, I was running out of patience so I also Restored Voice Factory defaults (Administration - Factory Defaults).
I then did the following config:-
Line 1
Proxy and Registration
Proxy:- "Proxy Server Name"
Outbound Proxy:- "Proxy Server Name"
Subscriber Information
Display Name:- Line1
User ID:- "My ID"
Password:- "My Password"
Auth ID:- "My Auth ID"
I left everything else default.
It is now working with no issues.
Was it worth going through this?????
I had a modem with built in ata and the voice quality was very poor, the spa122 has great voice quality and is now stable so I am very happy with it.
903
