Community Member
SPA 112 Sip Port doesn`t change
Good day, there is a problem with spa 112. i want to use different sip port like 23405, i change it in web gui under SIP PORT it is aplied but really no, spa 112 continue to connect on port 5060? is there any resolution about this problem? version is 1.4.0
Everyone's tags (1)
SPA devices are supported in
SPA devices are supported in the SMB community, you might want to move this there.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
yes if u can pls move, and u
yes if u can pls move, and u really think that ur answer solve my problem?
It's YOUR post, YOU have the
It's YOUR post, YOU have the option to move it, not me.
java
143
