Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
pk
SPA 122 stopping serve TR-069 requests after receiving RebootRequest
After my spa122 receiving RebootRequest from my acs - it stops serving any tr069 actions.
Embedded  connection request http server on port 8890 stopping and reply only connection refused.
No inform messages is sent after request received. Reboot also not occurs.
Request from acs:
<?xml version='1.0' encoding='utf-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:cwmp="urn:dslforum-org:cwmp-1-0" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><soapenv:Header><cwmp:ID soapenv:mustUnderstand="1">acs_4</cwmp:ID><cwmp:HoldRequests soapenv:mustUnderstand="1">0</cwmp:HoldRequests></soapenv:Header><soapenv:Body><cwmp:Reboot><CommandKey/></cwmp:Reboot></soapenv:Body></soapenv:Envelope>
Log from device:
Sep 11 03:12:49 SPA122 authpriv.debug : [TR69] accepts socket 4 connection from IP 83.243.72.103
Sep 11 03:12:49 SPA122 authpriv.debug : [TR69] ***** now=1441941169, inv=13, LastInform=1441941156, LastReqTimer=0
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] (271)ret=0 SIZE=9
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] (308) InfoEvent[EVENT_VAL_CHANGE].set=0 lsize=0
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.DeviceSummary
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.DeviceInfo.HardwareVersion
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.DeviceInfo.SoftwareVersion
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.ManagementServer.ParameterKey
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.ManagementServer.ConnectionRequestURL
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.GatewayInfo.ManufacturerOUI
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.GatewayInfo.ProductClass
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.GatewayInfo.SerialNumber
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] Name = Device.LAN.IPAddress
Sep 11 03:12:57 SPA122 authpriv.debug : [TR69] event=6 CONNECTION REQUEST, key=
Sep 11 03:12:58 SPA122 kern.debug [17180097.064000] sysevt_comm_sendto: (109, rc)=>
Sep 11 03:12:58 SPA122 authpriv.debug : [TR69] (63) length=0, count=0, bufidx=0, buflen=0
Sep 11 03:12:58 SPA122 authpriv.debug : [TR69] (74) length=0, count=880, bufidx=320, buflen=320
Sep 11 03:12:58 SPA122 authpriv.debug : [TR69] [start_server]CHUNK: size is null, continue get content!!
Everyone's tags (1)
This is the Video Over IP
This is the Video Over IP community, you probably want to move this over to the SMB community where the SPA's are supported.
java
if this helps, please rate
www.cisco.com/go/pdi
pk
Can anybody move this
Can anybody move this question to right thread ?
It's YOUR thread, you should
It's YOUR thread, you should have and edit button to do it.
java
123
