SPA112 and ipv6
How to enable ipv6 in spa112 to accept setting fx line with ipv6 and asterisk 1.8 ??
1 ACCEPTED SOLUTION
VIP Gold
SPA112 is declared to be IPv6
SPA112 is declared to be IPv6 upgradeable. But no such upgrade is available as far as I know. Do you have SPA112 with IPv6 support ?
On the other side, why you are asking for something like it ? SPA112 is not suitable for deployment into public IP addresses. For private, closed, LAN you can use private IPv4 addressing scheme.
In advance, IPv6 is brand new feature for Asterisk 1.8. There are some issues on the Asterisks side. You should consider to avoid IPv6 for production deployment.
VIP Gold
Hi Dan thank's.When cisco
Hi Dan thank's.When cisco turn this firmware upgrade to accept ipv6 ?? I want to use so spa112 public. But no deployment production.
VIP Gold
My humble opinion ? Never
My humble opinion ? Never.
Cisco is spending insufficient resources even for patching known bugs.
Forget new features. But don't forget I'm not affiliated with Cisco in any way. I'm guessing only.
Note, I consider IPv6 to be inessential feature, personally. SPA [1235]xx devices are not stable nor secured to be exposed on public IP.
Which cisco ata product
Which cisco ata product supports public ip secured ?
VIP Gold
I can recommend none to you
I can recommend none to you.
Connect it to known switch outside (or two, three ...) only. You may allow connections from other (known) phones with no intermediate switch as well. Use firewall or so to make it unreachable for connections from other (unknown) sources. Never expose SPA [1235]xx device to be reachable by just anyone.
It apply to untrusted devices connected in the same LAN as well!!!
Note my "Dangerous default, bill fraud may occur". SPA devices needs to be isolated from all untrusted devices, regardless they are local or external.
372
