SPA112 crash after SRV enabled
Hi everyone,
I working for ITSP. We have many of this product with different firmware(1.3.0 - 1.3.3).
When i set SRV redundancy enable on  the SPAs, after about a month they crash at same time .
If SRV off there is no problem.
It could be a memory leak or someting else.
I monitoring SPAs and one of this have below 4Mb free memory.
What should i do to work this feature well?
Kind Regards
Everyone's tags (1)
The best way is contact STAC
The best way is contact STAC and open a case.
Regards.
Where do I find that?Can you
Can you send me a link ?
Hi. You can find contacts
Hi. You can find contacts here: http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Regards.
120
