SPA112
I registered with VOIP provider and they game the the configuration  for Cisco VOIP
I made the sitting but i faced a problem
when i pick the phone i hear the normal tone for 1 second the start give me busy tone
i e-mail there technical support the told to change the proxy name
i did it but know use
this the configuration what the the put in there web sit
Proxy                                                  ata.nymgo.com
Make call without Registration           NO
Answer call without Registration        NO
Register                                             YES
Registration expires                           300
Display name                                    Your first name and last name
User ID                                              Nymgo username*
Password                                          Nymgo password
Auth ID                                              Nymgo username
Use Auth ID                                      YES
Preferred Codec                               G729
Use Preferred Codec only                YES
DTMF Tx Method                              RFC2833
Silence Supp                                      YES
Enable Fax CED Detect Enable       YES
so can you please help me to solve this problem
thanks
1 REPLY
VIP Gold
It may be caused by dial plan
It may be caused by dial plan or by regional settings. No settings you listed affects the length of dial tone.
Assuming you have no OEM/preprovisioned unit you should reset unit to factory default. Then configure phone according the configuration you described.
78
