SPA122 DTMF dialing repeat numbers & Firefox issues
Hello
I'm trying to configure my new SPA122 (firmware 1.0.2.006) with DTMF AUTO, Inband or AVT in any Spain phone provider but I have problems with repeating numbers when I call a number. With DTMF INFO I got DTMF dial tone working correctly, but ¿Cisco will solve in the next firmware update or a beta release?
I have a SPA3102 and PAP2T with DTMF Auto and I had no problems dialing in any Spain provider.
Another problem I have with the SPA122 is the web management does not load properly with Firefox 7.
Regards.
Please try changing the DMTF Tx Mode from Strict to Normal and see if that works out.
Re: SPA122 DTMF dialing repeat numbers & Firefox issues
The problem is when I use ip dialing and try to use the PSTN line of SPA3102, the results were:
SPA122:
DTMF Tx Strict and DTMF Info = Call Ok
DTMF Tx Normal and DTMF Auto = Call Ok, but PSTN Line does not disconnect correctly.
Any other convination in SPA122 repeats numbers when dialing,  However in PAP2 with DTMF Tx Strict and DTMF Auto call Ok.
Regards.
1585
