SPA122 - IVR Factory Reset Parameter not functioning
Hi Team,
We are currently experiencing an issue with the SPA122 [firmware ver. 1.2.0 (022)] whereby the following parameter does not seem to be working on the device.
<Protect_IVR_FactoryReset ua="na">Yes</Protect_IVR_FactoryReset>
We can see that the parameter is being changed (from No to Yes) through searching on the parameter list under:
http://192.168.15.1/admin/config.xml
However when 73738# and 1 is dialled the device will factory reset and lose all provisioned parameters.
Please advise on what can be done to prevent this from happening.
David Parr
Symbio Networks
1 ACCEPTED SOLUTION
Hello David,
The functionality with the parameter has now been resolved in the latest pre-release firmware for the SPA122.
Please open a case with our support center who can then provide the firmware to you.
Information can be found at the following website:
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Best regards,
-Lance Harper
Cisco Systems, Inc
Apologies,the firmware version should read: firmware ver. 1.2.0 (020).
David
Hello David,
Best regards,
-Lance Harper
Cisco Systems, Inc
Hi Lance,
Any indication on when the next official release firmware will be out? Will it be some time this month?
2020
