SPA122 Randomly Changes IP Address
SPA122 Randomly changed IP address.
Connected to the internet thru router and Modem via the blue ehternet jack.
When first installed - IP address was 192.168.1.116 - was supposed to be 115 according to the manual. After a few days, it changed itself to 192.168.1.112.
That stayed for a while - now it vhanged again to 192.168.1.111
Why is this happening???
Update - it did it again this morning - now went to 192.168.1.110
Am beginning to think that Cisco gear is junk...
Linksys was way better until Cisco bought them and screwed them up also....
1 ACCEPTED SOLUTION
hi I think your issue is that
hi
I think your issue is that the wan IP address is set for dhcp, and your router may be giving out another IP address.
You can go into the router --> wan settings and give the wan port a static IP address. That will keep it from changing when dhcp renews.
If this does not resolve the issue, please call in 866-606-1866 or go to the cisco site, click support -> open a case.  We'll be glad to help you.
Dan
hi
Dan
Dan,You are absolutely
Dan,
You are absolutely correct!!
I had done that at the suggestion of a friend about 3 days ago, and since then all has been good..
Thank you for the offer of help, but I think all will be Ok now.
Jack
no problem, remember you have
no problem, remember you have a year of free tech support if you need a hand.  3 years if you buy a contract.
Dan
Ok, Thanks Dan...
Ok, Thanks Dan...
176
