Community Member
SPA122 SNMP Trusted IP Address - doesn't
Hi:
I've set the SNMP Trusted IP to be a single host (i.e.: 32 bit mask) and I can still access the SPA122 SNMP agent from other IP addresses which should not be the case.
Has anyone else seen this behavior?
Model:SPA122, LAN, 2 FXS
Hardware Version:1.0.0
Boot Version:1.0.1 (Oct  6 2011 - 20:04:00)
Firmware Version:1.1.0 (011) Feb 10 2012
Recovery Firmware:1.0.1 (005)
Dale
Everyone's tags (3)
Community Member
Bug opened with Cisco.
Community Member
I was told by Cisco engineering that this setting is only applied to connections from the WAN side and does no filtering of connections from the LAN side.
1449
