SPA203D Dect 2 - 10 Not picking up SIP credentials from base station
Hi There
Installing 4 x SPA203D Dect handsets tied to the base station SPA232D.  All handsets are registered and sync'ing with the base station but the SIP credentials are being populated from the quick setup (Dect 1). Under the Voice menu each Dect has its own SIP credentials but these are not being Sync'd to the handsets.
All firmwares are up to the latest version.
Have I missed something in the setup?
  • ATAs Gateways and Accessories
VIP Gold
SPA203D handset doesn't speak
SPA203D handset doesn't speak SIP protocol itself. They are DECT handset, so speak DECT to base station. The the base station speak SIP only.
So, what you mean "SIP credentials are not synced to handset" ?
May be I just misunderstood the issue ...
so there is a matrix on the
so there is a matrix on the quick setup page if you scroll down.  that assigns the DECT line to one or more handsets.
the default is all handsets to dect line 1.  so choose handset 1, check dect line 1, handset 2, 2 etc...
click voice --> Dect line 2-10 to configure the proxy/username/password/authID, etc
This doc, describes basic setup to dial plans, using alternate providers using GW1-9, etc.  It is really worth going through with the ATA in front of you.  if you have already set up the handsets skim through the first several pages.
https://supportforums.cisco.com/document/128181/spa232d-spa302d-getting-started-advanced-call-routing-scenarios
hope this helps,
Dan
75
