SPA2102 FXS port not hanging up
we have an issue where any FXS port is staying up, after a remote caller hangs up. Debug does show a SIP BYE but the FXS port stays off-hook. Could this be a configuration issue?
Many thanks,
Kev
Green
Kev,
Never worked on these but may be this will help
http://www.cisco.com/en/US/products/ps10024/products_qanda_item09186a0080a36ad5.shtml#15
15. How does SPA indicate a disconnection when the device's FXS port is connected to PBX?
The SPA device will generate a Calling Party Control (CPC - disabled by default). To enable this function, proceed to the Web Configuration utility and from the Regional tab, change the value for the CPC duration to some value other than 0. When the SPA device is the called party, the CPC duration is the "voltage drop" duration before hearing dial tone again.
Alex
Regards, Alex. Please rate useful posts.
Thank for the reply Alex.
Unfortunately it's a DECT base station terminating on the FXS port and not a PBX, sorry should have mentioned!
I'm wondering if it's just a limitation of the base station or if it's normal behaviour to leave the line open. The issue for our customer is that if they don't hang the DECT handset up after a call, the line does stay open, which does make sense but I wanted to see if there was a definitive answer on this.
Cheers,
Kev
588
