SPA2102 POINT TO POINT with 3660 with FXS without SIP server
I' need some information about if it's possible to configure a 3660  router with 2 FXS interface to communicate with SPA2102.
I' d like to know which is the configuration that i have to set up on the 3660 to do voice call with a spa2102.
It's sufficient configure this parameters:
dial-peer voice 1 pots
destination-pattern 901 (my phone number)
port 5/0/0
dial-peer voice 200 voip
destination-pattern 201
session target ipv4:xx.xx.xx.xx (ip address spa2102)
session  protocol sipv2
Thanks a lot and Best Regards
Carmine
Yes, your config is sufficient.
This is my configuration:
voice call send-alert
voice rtp send-recv
dial-peer voice 1 voip
description INCOMING_DIAL_PEER_INCOMING_CALLS
incoming called-number .
modem passthrough nse codec g711alaw
voice-class codec 10
fax protocol pass-through g711alaw
no vad
dial-peer voice 2 voip
description TO_REMOTE GATEWAY
huntstop
destination-pattern 5..
session target ipv4:IP_ADDRESS_REMOTE_GATEWAY
session transport udp
dtmf-relay rtp-nte
codec g711alaw
fax rate disable
no vad
dial-peer voice 10 pots
description FROM_REMOTE_GATEWAY
huntstop
destination-pattern 610
port 2/0
sip-ua
disable-early-media 180
max-forwards 10
retry invite 3
timers expires 60000
no suspend-resume
Change Line parameters of your SPA2102 as shown in the figure below and configure appropriate phone numbers.
Regards.
Thanks a lot
Carmine De Rienzo
701
