SPA3102 2nd linea Fritz!box
TecnicoLink
Hello, i need to configure a SPA 3102 to use in associating with a Fritz!Box to make and receive call on a PSTN line. I have a 2nd line that i need to connect with Fritz!Box. What is the correct configuration of the spa 3102 to do so?
Thank you
Jaime Valencia
SPA phones support is in the SMB community, you can also try resources like voip.org
java
if this helps, please rate
