Small Business Support Community
Explore what Cisco has to offer for your small business IT needs. Learn from your peers and Cisco experts.
Browse the Community
Routers - Small Business
Routers tailored for small businesses, providing efficient and reliable connectivity for your growin...
Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small busi...
Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost product...
Cisco Business Dashboard
Stay on top of your business performance with the Cisco Business Dashboard, providing real-time data...
Activity in Small Business Support Community
CBS350-24P-4X Rackmount disalignment
Hi community,I'm a bit confused...I recently got a CBS350-24P-4X 1U managed switch, which comes with a wall-mount/rack-mount (I guess?) kit and I'm wondering, how I could manage to install this kit onto the device in order to align the rackmount-ears...
CBS350, private VLAN, DHCP
I have a CBS350 switch that is set up to do inter-VLAN routing and provide DHCP addresses. That has been working without any issues for quite a while. Recently, I have created a private VLAN on it which is working okay except for one issue. I cannot ...
KJK99 by Level 1
  • 1070 Views
  • 11 replies
Resolved! PSA: Avoid CBS350 Switches - Critical POE Defect
Hello Community, I'm writing to let you know that there is a critical POE defect in the CBS350 switches and you should avoid them if you require stable POE operations. This apparent software defect causes POE ports to randomly fault after 8 to 12 hou...
d0nni3q84 by Level 1
  • 18200 Views
  • 49 replies
fiber port not coming UP
we have CBS350-24P-4G fiber port not coming upNAME: "GigabitEthernet25" DESCR: "SFP-100Base-LX"PID: SFP-100-LX VID: Information Unavailable SN: 9802222809DataSwitch1F#sh fiber-ports optical-transceiver interface gi25Port Temp Voltage Current Output I...
UDI Product number
hi, by mistake i wrote the UDI product and serial number the same by mistake  i need your help to change the UDI product
sakeral by Level 1
  • 78 Views
  • 0 replies
RMA delivery for Singapore Site
Hi Cisco Team, Our Customer in indonesia have cisco devices installed in Singapore Site. Those devices using 8x5 nbd smartnet. Our question are: 1. If there is hardware failure the RMA part will be deliver dorect to singapore or to indonesia first? 2...
OOB port not respond on 350X
Hi, I tried to connect to OOB port for management, but I can't connect to it. The port not answer to ping too.I can connect to console port using serial cable.The port OOB seems well configured.
Resolved! Cannot change password on CBS250 switch
Hey,I simply cannot change a password on the CBS250-8T-D in my lab. No matter what password I try (I tried a bunch ranging between 10 and 14 characters), I'm always gettingPassword rejected - Passwords must not match words in the dictionary, and mus...
nahk by Level 1
  • 4108 Views
  • 9 replies
  • 6 Helpful votes
Login Problems
Can someone of CISCO help me with my login problems ?federated identity cisco.comBest regardsIvan Conte
Resolved! All Cisco RV Routers EOL. Perhaps new CBR line coming?
So the Cisco Small Business RV340, RV345, RV 160, RV260, RV345P, RV340W, RV260W, RV260P and RV160W VPN Router has all reached EOS & EOL.  That's every small business router that Cisco currently has.  Per Cisco, there is currently no product migration...
WAB-IT by Level 1
  • 8174 Views
  • 23 replies
Top Experts - Last 30 Days
