Community Member
SPA3102: Integration into LAN?
Hello everybody,
I need help, I'can't bring the SPA3102 working.
My wanted configuration:
  • LAN with static IP adresses
  • Router ( connected with the cable modem
  • SPA3102 ( connected anywhere to the LAN (using several switches)
  • A lot of ethernet devices
I've access to the 3102 by browser. But how can I manage, that I can connect with a phone to the Internet?
I didn't found any docs describing my problem. Also, there is NO USER MANUAL available for this device!
I hope, anybody can help me. I've a lot of Linksys / CISCO devices, but now I guess, this was the last one...
Thanks a lot to all - bye Peter
Everyone's tags (5)
Hall of Fame Super Gold
Wrong forum, post in "small business voice - ATA and gateways". You can move your post using the actions panel on the right.
Community Member
Dear Paolo,
thanks for reply, I moved my call now. Have a nice summer!
Bye - Peter
Re: SPA3102: Integration into LAN?
If you setup the SPA3102 for a static ip address, i.e.
Router-->WAN Setup-->Connection Type--> Static IP
then you must setup the Primary DNS: and Secondary DNS:  to do the DNS lookups for your symbolic ip addresses used in the configuration.  You must also connect the WAN ethernet port to the internet source
You can find a quick SPA3102 Setup Guide:
You can find a detailed SPA3102 Administration Guide:
