Community Member
SPA3102 Unlock help
I have a Linksys SPA3102 unit which was given to me,
The unit is locked and was originally purchased from MyNetFone.
The original owner closed down their account and no longer needed the unit.
I am trying to access the Admin settings to reuse the unit, however the unit is locked.
MyNetFone support have told me I need to contact Cisco Support to get the unit unlocked.
Cisco support won't help me because the unit is out of warranty.
Is there any way to get this unit unlocked or is it a useless brick now, because no one will help me unlock it.
Everyone's tags (1)
1 REPLY
I suggest you move this to
I suggest you move this to the SMB forum where the SPAs are supported.
java
if this helps, please rate
www.cisco.com/go/pdi
128
