SPA400 Voicemail Module FIles
It appears the USB stick that has my current Voicemail for my SPA400 has decided to die on me and is showing as 'Unmounted'.
Does anyone have a link to the files needed to build  anew USB stick please?  Have tried Google and keep getting the tech note on how to rebuild but the link to the downloads does not lead to where it should.
Cheers in advance
Hi there - did you ever find
Hi there - did you ever find this? I need the same!!
RussH.
HiI did but can't for the
I did but can't for the life of me remember where I found the files......have slept a lot in since then.
Will have a look when I get back into work and see if I can find them there.
Hi, Luckily, I managed to get
Luckily, I managed to get the files !!!
I didn't find them on the web. I managed to get them from the reseller of SPA !
Good to read that. Is there
Good to read that. Is there any chance to get a copy of your configuration files?
In my case the reseller told me that I don't need those files, and he says that he does not have those anyway. But we both know that those files are necessary.
Greetings, Did you able to
Greetings,
Did you able to find those files? i'm trying with different combinations but i can't find anything about spa400vm.zip
93
