spa8800 as standalone voip solution with ip phones
Hi Everyone,
I've  recently been handed a cisco spa8800 to configure and I'm wondering if  it is possible to use the device with a couple of spa941 IP telephones.
I'm aware that the spa8800 can interface with an asterisk box, though the requirement doesn't list one.
Is there anyway of achieving this?
Am happy to provide more details and bounce around ideas as needed.
Matt.
Hi matt,
Unfortunately the SPA8800 is not a Call Control, then if you wish to use the SPA941 you should use it with IP Dialing (option can be enabled after Dial Plan Field).
The SPA8800 can interface with asterisk without problems, we have in this community some guides to do this kind of configuration in SPA Phones, you can use the same guide and adapt to your needs.
https://supportforums.cisco.com/docs/DOC-9955
Please let me know if it answer your questions and if you need further information.
Andrey Cassemiro.
I'm sorry, there was an exactly doc.
https://supportforums.cisco.com/docs/DOC-9899
I have spa 8800 which can configured the incoming but out going is not working.I think my dial plane is not corrected.how can i configure out going.
4045
