SPA8800 Fault
I have a ~13 month old SPA8800 that won't start. I changed the FXO and FXS ports from UDP to TCP and saved the configuration. It's now stuck in a loop during the boot cycle. The power light comes on followed by the Ethernet, then the status lights 1 to 4. After all four lights come on the box restarts.
You can hear the relays on the board clicking as each status light comes on. The box has the 6.1.7 firmware.
I can't do a factory reset as I never get a dial tone. Is there anything else I can do to reset it?
1 REPLY
SPA8800 Fault
Try disconnecting the ethernet cable and then with an analog phone connected to phone port 1, dial the IVR with **** and see if you can have the unit accept the digits for RESET (match up the letters with the digits on the phone).   See if it replies with enter 1 to confirm and then do so.
1082
