UC560 CUE not working--gives error "your recording is too short, record a longer message"
I have a UC560 running Unity Express 8.0.3 that is having voicemail issues. After a CUE reload, if a call goes to voicemail the caller gets a message saying "your recording is too short, record a longer message"; at this moment, an error shows up in the CUE session saying "localhost postgres: voicemail aesop [local] idle in transaction:   CRASH sql sql sql PANIC:  failed to add item to the right sibling for "pg_largeobject_loid_pn_index".  After this error appears, any calls forwarded to voicemail just ring until they eventually disconnect.
I have confirmed that we are not exceeding maximum storage.
Is this a corrupt database? Would resetting the CUE to factory defaults help?
1 REPLY
Hi Mike,Was your issue solved
Hi Mike,
Was your issue solved? as I am facing same issue.
Please share your solution with me.
Thanks.
150
