VOIP Adapter?
Is there anyone that can recommend a VOIP Adapter that works with franking machines? I have been told that the specification it has to meet, is
asynchron/duplex  2400/2400 bit/s  (V22)
asynchron/duplex  1200/1200 bit/s  (V22)
asynchron/duplex  300/300 bit/s  (V21)
Can Linksys PAP2T-NA do the job? Does anyone have any experience with this?
Best regards,
Kaj Størdal Toftner
Re: VOIP Adapter?
Have you tried the Cisco ATA 186 Analog Telephone Adapter? I have used it on FAXes and Fire Alarm Systems successfully.
Re: VOIP Adapter?
Thanks a lot for your advice. I have finally got two units of Cisco ATA 186. But, I am missing the IOS that are supporting SIP telephone accounts.  Do anyone know how do I get that? And, the easiest way to load the image, when I do not have any TFTP-server?
Re: VOIP Adapter?
Hi KajToftner,
Take a look at the ATA data sheets listed here and then choose the one that best meets your needs.
https://www.myciscocommunity.com/docs/DOC-2149
Patrick
1733
