Wall mounting a SPA3102
Why are there no wall mounting slots on the bottom of the SPA3102?
  • ATAs Gateways and Accessories
Everyone's tags (1)
Re: Wall mounting a SPA3102
My 3102 has two punch outs (look like a T), see if yours has that and you can punch those out so that you can put two small screws in a wall and hang the unit via the punch outs.
I've tried punching them out.. just distorted the back.. then I tried carefully drilling through the back (thereby destroying one unit)..
Why didn't CISCO punch them out (while putting some barrier between the intended screws and the PCB)? I need to hang these! The only way I see now is removing the rubber (sticking) covers to the screws holding the unit together.. removing the entire back.. the trying to drill holes - this is not a typical solution - is there some point on these punchouts that will yield?
it should have this. in order to distribute heat.
1283
