What is the firmware version installed on the WRP400?
The 2.00.26 is, in my opinion, the most stable version.
Is the WRP used as VoIP ATA also?
If no, I suggest you to disable voip service and change SIP default port.
If yes, I suggest you to change SIP default port and enable Restrict soure IP option.
Regards.
