Wrp400 provisioning
Sorry for the English , I use Google translation.
I have several WRP400 , I have studied the manual provisioning and everything works perfectly .
I managed to put all the parameters I want.
Against by the only that does not work , the Wireless.
When I get the line on the cfg file, the WRP400 takes no parameters and does not update , as soon as I removed the wireless line is everything is OK.
These are the lines that I tried without success : I want to WPA2 Personal + key 8 digits
and :
<WL_SECURITY_SET_1> Wl_security_mode2 = wpa2_personal , wl_crypto = aes, wl_wpa_psk = personal, wl_wpa_gtk_ rekey = 700 </ WL_SECURITY_ set_1 >
It does not work , after three days of testing, I have come to ask a help on forun because I do not.
If You have the coneils , thank you .
Thank you for reading me
1 REPLY
Re: Wrp400 provisioning
Do you have included the wireless option in the tag?
This is a profile example:
http://www.sipura.net/xsd/WRP400" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.sipura.net/xsd/WRP400 http://www.sipura.net/xsd/WRP400/WRP400-2-00-30.xsd">
Yes
60
  wl_wme=off,wl_wme_no_ack=off
  QoS=0,rate_mode=1
  rtsp_enable=0
  force_igmp_version=2,multicast_pass=0,multicast_immediate_leave=0
  mobile_automode=0
  time_zone=+01 2 2,daylight_time=1,ntp_mode=auto,ntp_server=,timer_interval=3600
  remote_upgrade=1
  softirq_active_voice=0,softirq_polling_cnt=1
  mw_reinit=1,mw_interval=0,mw_weekday=6,mw_time_hour=3
I suggest also to upgrade the firmware to latest version. In this way all provisioning options are supported.
Regards.
431
