Cisco AnyConnect and Cisco ASR 1000
We are currently using Cisco VPN Client for Windows 7 connecting to Cisco ASR 1000 and Cisco 3925 Routers.
To start using Cisco AnyConnect Client with existing Routers:-
1. Will the client still work with Router IOS ?
2. What additional configuration is required if not ?
  • Borderless Networks
Everyone's tags (1)
Silver
VPN client you are using is
VPN client you are using is Ipsec based client whereas Anyconnect Client is SSL based VPN.
1. Will the client still work with Router IOS ? Yes 3925 supports and  you need license. Also  IOS version  15.0 & above
2. What additional configuration is required if not ? As it is totally different yes need different configuration. you will need a certificate for you VPN address . Link below have some configuration ideas.
http://www.cisco.com/c/dam/en/us/td/docs/routers/access/cisco_router_and_security_device_manager/application/notes/WebVPN.pdf
Check for all required for Router based VPN. We are running on ASA.
http://www.cisco.com/c/en/us/products/collateral/security/ios-sslvpn/product_data_sheet0900aecd80405e25.html
 What Anyconnect version can
What Anyconnect version can I use to work with Cisco 3925 IOS 15.x   ?
Silver
Please check your requirement
Please check your requirement and see what version would be the right for your scenario. Otherwise you can use the latest version . Such as if you need Windows 8 support then the first version which support is 3.1.04072 & later.
Please check the example using version 3.1.00495
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/904-cisco-router-anyconnect-webvpn.html
Hi, Thanks for additional
Thanks for additional info.
I have uploaded anyconnect pkg to router and configured as per instructions provided.
How do I download the client to windows from internet or do I have to do this from the Lan only ?   Do I just specify the gateway address of router using https ?
1527
