Webcast-Catalyst9k
How can use internet bandwidth load balancing between two ISP from cisco asa 5510 firewall
how can use internet bandwidth between twi ISP
1 REPLY
firewalls can not do loadbalncing with cef over differnt interfaces like a router
however what you can do is connected the Internet links to a shared LAN using same subnet
in the FW use two static default route each one point to one Internet link next hop over one FW interface
otherwise use a loadbalncer or a router for better out come
1122
