Hub / 50 Spokes - product considerations
A client is in the beginning stages of considering a network overhaul. The design would include a central hub with roughly 50 spoke locations. The traffic at the spoke locations would be /very/ minimal. Think 1-2 endpoints at each spoke.
Ideally every spoke device would be the same. The hub office would have to be able to push a fair amount of traffic. What would be appropriate models to look at? I was hoping to implement dmvpn but cost is a consideration and the client is leaning towards something like the ISA500 for the spoke locations.
Any ideas or models to look into would be great.
1 REPLY
well 50 is not a big number for the hub you can consider 2900 or 3900 ISR router
for the spoke any simple small router with desired features can be used, for the ISA500  you need to double check of DMVPN is supported as you are planing to use it
hope this help
862
