05-12-2014 04:25 AM - edited 03-03-2019 07:23 AM
Which is the best traffic load balancer, with 3-4 WAN ports and 1 LAN? what is your experience with it? Does Cisco have any equipment that performs load balancing? What are other vendors options?
Best regards,
Brj
05-23-2014 10:22 AM
Hi asbesi001, for loadbalancing, you may check the Cisco 890 Integrated Services Router (http://cs.co/9009i2CB). Aside from loadbalancing feature, the ISR's are actually considered as Cisco's all in one box solution. Feel free to message me for further assistance. Hope this helps!:)
Angela (ageralde@cisco.com)
07-02-2014 07:05 PM
I would suggest taking a look at F5. They offer true L7 load balancing with a myriad of options. IOS has a limited load balancing feature set.
07-04-2014 06:17 PM
Hi asbesi001,
If you have Cisco Router you can use pfr feature but it has many limitations, Cisco doesn´t have a effective load balancer.
Regards.
