Load balancer!
Which is the best traffic load balancer, with 3-4 WAN ports and 1 LAN? what is your experience with it? Does Cisco have any equipment that performs load balancing? What are other vendors options?
Best regards,
Brj
Everyone's tags (1)
Hi asbesi001, for
Hi asbesi001, for loadbalancing, you may check the Cisco 890 Integrated Services Router (http://cs.co/9009i2CB). Aside from loadbalancing feature, the ISR's are actually considered as Cisco's all in one box solution. Feel free to message me for further assistance. Hope this helps!:)
Angela (ageralde@cisco.com)
I would suggest taking a look
I would suggest taking a look at F5. They offer true L7 load balancing with a myriad of options. IOS has a limited load balancing feature set.
Hi asbesi001,If you have
Hi asbesi001,
If you have Cisco Router you can use pfr feature but it has many limitations, Cisco doesn´t have a effective load balancer.
Regards.
54
