Webcast-Catalyst9k
Need To configure Two point to point link on cisco 1841 router with load balancing
Hi team,
I am having Cisco 1841 router and one single point to point link has configured on the router. We are going to planing to terminate one more point to point link on Cisco 1841 router and we need to load balancing on the router.
Can any one tell me is it possible to terminate two Point to point link with load balancing possible in cisco 1841 router?
And if yes then can you provide the configuration commands for the same.
Thanks In advance.
1 REPLY
 Yes, you can use multilink
Yes, you can use multilink point-to-point protocol to achieve this requirement.
reference doc for you:
http://www.cisco.com/c/en/us/td/docs/ios/ios_xe/wan/configuration/guide/xe_3s/wan_xe_3s_book/wan_cfg_mlppp_conn_xe.html#wp1058765
291
