Network design Issue
Hello everybody!
I am going through a network problem  and I believe to be some problem related to network design.
Our network is distributed in two sites, each with 2 routers interconnected by two different data link.
The main link (fig.) is connected to the second router of each side (JAG_rtcftv02 / PAR_rtcftv02) at the interface GigaEthernet 0/1 (L3 interface).
The secondary link, the first router on each side (JAG_rtcftv01 /PAR_rtcftv02), is connected to corporate network by a trunk interface FastEthernet 0/0/0 (L2 interface).
We have two different networks on the left side wich are supervised by the management at right side.
We are using a ring topology and a star topology. Both are connected by trunk of each router card (HWIC-4ESW / Fast Ethernet0/0/1 and 0/0/2).
Routers are running HSRP for redundancy.
The problem happens every time I change some wiring in the star network, ultimately affects the stability of the ring network and stopping some circuits.
What may be affecting this? I believe this connection to the secondary link (Fast Ethernet 0/0/0) is causing problemsSpanning-Tree but not sure.
I ask for some help!
Everyone's tags (3)
Re: Network design Issue
Hello Tarik,
Can you post some more detail on the layer 2 domain you are having issue with? It doesn't look like a star or ring topology in your diagram.
Jamie
Hey tarik,
Some quick questions...
- Which device is th root bridge?
- is there a connection between the primary and secondary routers on each side?
- can you paste you HSRP configs. for each device?
- Are both primary and secondary routers connected to the corporate network via dot1q trunk?  If not, please provide details.
Thanks.
707
