PPPoE disconnection via POD from freeradius
I am setting up a broadband architechture using freeradius and cisco router as a NAS. I am unable to disconnect PPPoE sessions using freeradius.
Can you assist for PoD or best possible method to acheive it? It would be a great hekp,
1 REPLY
Hey i found the solution to
Hey i found the solution to it by adding ignore session-key
ignore server-key under aaa accounting of cisco radius config. below is the config
aaa server radius dynamic-author
client <radius ip address>
server-key cisco
auth-type any
ignore session-key
ignore server-key
aaa pod server auth-type any server-key cisco
Radius config for radclient is also mentioned below.
# echo "Acct-Session-Id=D91FE8E51802097" > packet.txt
# echo "User-Name=somebody" >> packet.txt
# echo "NAS-IP-Address=10.0.0.1" >> packet.txt
# cat packet.txt | radclient -x 10.0.0.1:3799 disconnect ''secret''
Sending Disconnect-Request of id 214 to 10.0.0.1 port 3799
      Acct-Session-Id = "D91FE8E51802097"
      User-Name = "somebody"
      NAS-IP-Address = 10.0.0.1
rad_recv: Disconnect-ACK packet from host 10.0.0.1 port 3799, id=214, length=20
577
