Community Member
Redundant Transparant ASA between Redundant Routed Links
Aparently the Security/Compliance team didn't review my network design before it was submitted and built, and now I have to shoe horn a firewall somewhere there was never supposed to be one.
I have my two current DC Cores (Nexus 5548UP), that currently are Layer 3 only, with no L2 configuration at all.  I understand these aren't the best switches for this role, but the BoM was put in place and gear ordered, long before I came onboard, and the DC design had been completed.  From these two Cores, i connect directly to a vendor's clustered Fortinet FW, via a /30 from each core to each node of their cluster, and connected via eBGP, one link with a path prepend, due to the vendor not able to figure out how to load balance on their firewall.  Due to numerous vendor problems, and lack of knowlege, I cannot get them to change their design in a timely manner, to meet our timelines, and this has to be up yesterday to be PCI compliant (so our security people say) prior to go live in 1 week.  The vendor took 3 weeks just to figure out how to aggregate routes to me!.
So I want to drop a transparent pair of firewalls inline on the two links, but due to the Active/Standby limitation of ASA's, I am not sure this will be that easy given the /30 L3 interfaces being used.  Secondly the lack of L2 between the two upstream cores may be a concern, at least from past expiriences.  I know if I was using some other vendor's clustered FW, this wouldn't be a problem, but I definately don't want to join the Dark side again, or do I have time to procure any other equipment other than the 5520's I currently have laying around.  Someone please tell me I have overlooked something simple, and the design listed below will be simple to implement!!!!
Any ideas appreciated!
Community Member
Re: Redundant Transparant ASA between Redundant Routed Links
why you don't use this design:
connect the vendor clustered direct to nexus with a vrf instance, then route traffic to asa and then route to nexus whith other vrf istance.
