Cisco 3750 Stack Incorrectly incrementing Total output Drops counter on the Output.
Device  -C3750X-48P Stack
Ios      15.0(1)SE1            C3750E-IPBASEK9-M
Issue Incorrectly incrementing Total output Drops counter on the Output.
I can only find a reference to the following Ios mentioning these are affected.
This is my first attempt at using the Bug search. Any assistance would be appreciated.
Known Affected Releases:
(2)
12.2(44)SE1
12.2(44)SE
ognvmels58c37#sh clock
06:42:21.315 UTC Mon Aug 11 2014
ognvmels58c37#sh int gi 3/0/27 | incl output drops
06:42:28.152 UTC Mon Aug 11 2014
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 400
06:42:34.107 UTC Mon Aug 11 2014
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4294966096
06:42:39.610 UTC Mon Aug 11 2014
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4294965696
06:42:45.465 UTC Mon Aug 11 2014
06:42:51.563 UTC Mon Aug 11 2014
06:42:56.806 UTC Mon Aug 11 2014
06:43:01.982 UTC Mon Aug 11 2014
06:43:10.563 UTC Mon Aug 11 2014
06:43:15.243 UTC Mon Aug 11 2014
Hall of Fame Super Gold
Post the COMPLETE output to
Post the COMPLETE output to the command "sh interface Gi 3/0/27".
GigabitEthernet3/0/27 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e8b7.4805.961b (bia e8b7.4805.961b)
  Description: Voice and Data
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:29, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 57000 bits/sec, 38 packets/sec
  5 minute output rate 58000 bits/sec, 45 packets/sec
     25517742 packets input, 5962733083 bytes, 0 no buffer
     Received 32547 broadcasts (474 multicasts)
     2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 474 multicast, 0 pause input
     43558330 packets output, 11502034968 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Hi Owen,I think you are
Hi Owen,
I think you are hitting the following known bug:
CSCtq86186
Help | Feedback Feedback
Switch stack shows incorrect values for output drops on show interfaces
CSCtq86186
Description
Symptom:
Switch stack shows incorrect values for output drops/discards
on show interfaces. For e.g.,
--- show interfaces ---
GigabitEthernet2/0/5 is up, line protocol is up (connected)
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4294967163
Conditions:
This is seen on Stackable switches running 12.2(58)SE or later.
Workaround:
None.
Further Problem Description:
The 'show platform port-asic stats drops' shows the correct values.
An example below shows how the snmp ifOutDiscards counters:
$ snmpwalk -c oaklweht 192.168.100.1 ifDescr.10124
IF-MIB::ifDescr.10124 = STRING: GigabitEthernet1/0/24
$ snmpget -c oaklweht 192.168.100.1 ifOutDiscards.10124
IF-MIB::ifOutDiscards.10124 = Counter32: 60297
IF-MIB::ifOutDiscards.10124 = Counter32: 120594
Customer Visible
Was the description about this Bug Helpful?
(10)
Details
Last Modified:
Dec 4,2014
Status:
Fixed
Severity:
3 Moderate
Product:
Cisco IOS
Support Cases:
481
(3)
12.2(58)SE
12.2(58)SE1
15.0(1)SE2
Known Fixed Releases:
(51)
12.2(44)SE6
12.2(46)SE
15.0(1)SY1
15.0(1)SY4
15.0(1)XJR111.346
15.0(2)EA
15.0(2)EB
15.0(2)EC
15.0(2)ED
15.0(2)EY
15.0(2)EZ
15.0(2)SE
15.0(2)SE1
15.0(5.2)DPB20
15.0(5.2)DPB35
15.0(5.23)SID
15.1(1)SG5.193
15.1(1)SG5.194
15.1(1)SG5.196
15.1(2)SG
15.1(2)SG1.90
15.1(2)SIV11.1
15.1(2)STV11.1
15.2(0.18)S0.3
15.2(1)S
15.2(1)S1
15.2(1.0.0)IPI2
15.2(1.1)EY
15.2(1.3)S
15.2(1.30)PSR
15.2(1.7)PI18f
15.2(2)SA
15.2(2)SNI
15.2(2.2)T
15.2(3)GC
15.2(3)GCA
15.2(3)T
15.2(3)T1
15.2(3)T2
15.2(3)T3
15.2(4)M1
15.2(4)M2
15.2(4)M3
15.2(4)S1c
15.2(4)S3
15.3(1)S1
15.3(1)T
15.3(1)T1
15.3(2)S
15.3(2)T
15.3(3)JA100
Upgrade to 15.0(2)SE or later and you don't have the weird output drops stats anymore.
Best Regards,
Christian
308
