CSCsw18530 - Power Imax / Tstart errors may be reported with some third party PDs - 3
We are exeriencing an issue with a customer on C2960S running 12.2(58)SE2 that is very similar to hte symptoms reported in this bug ID and we suspect it may be causing wireless access points to fail or enter safe-mode when the power is negotiated incorrectly.  However, according to the the bug ID CSCsw18530 it seems 12.2(58)SE2 may contain the referenced fix.  Can anyone athoratatively confirm this, or else advise on the correct known code version to implenent the fix for the C2960S?
hi ,
hi ,
i am getting this error on the cisco new 3650 E series switch , can anyone tell what should be the fix ? as per cisco bug tool CSCsw18530 , i tried to run the port command 2x mode but it didnt support .
Jul 11 06:55:09.973: %ILPOWER-7-DETECT: Interface Gi2/0/48: Power Device detected: Cisco PD
Jul 11 06:55:10.754: %ILPOWER-5-POWER_GRANTED: Interface Gi2/0/48: Power granted
Jul 11 06:55:14.121: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/48, changed state to up
Jul 11 06:55:16.122: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/48, changed state to up
Jul 11 06:59:03.459: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi2/0/48: PD removed
Jul 11 06:59:03.461: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi2/0/48: Power Controller reports power Imax error detected
Jul 11 06:59:04.251: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/48, changed state to down
Jul 11 06:59:05.254: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/48, changed state to down
Jul 11 06:59:12.661: %ILPOWER-7-DETECT: Interface Gi2/0/48: Power Device detected: Cisco PD
Jul 11 06:59:13.512: %ILPOWER-5-POWER_GRANTED: Interface Gi2/0/48: Power granted
Jul 11 06:59:16.823: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/48, changed state to up
Jul 11 06:59:18.822: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/48, changed state to up
Jul 11 07:01:09.395: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi2/0/48: PD removed
Jul 11 07:01:09.396: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi2/0/48: Power Controller reports power Imax error detected
Were you able to resolve this
Were you able to resolve this? If so, what was the fix?
959
