CSCtq62715 - ASA should not allow EtherChannel configuration on 4 port SSM module - 1
Has anyone experienced the opposite problem, etherchannel works fine on 4 GE SSM in module 1 of ASA5550 running 8.4 code, but no longer works when upgrade to version 9.1?
Config options using 8.4(4):
ASAconfig)# int g1/0
ASA(config-if)# ?
Interface configuration commands:
  authentication   authentication subcommands
  channel-group    Etherchannel/port bundling configuration
  ddns             Configure dynamic DNS
Config options using version 9.1(2):
ASA(config-if)# int g1/0
ASA (config-if)# ?
Gillian
1 ACCEPTED SOLUTION
Hi Gillian,
What you are describing is what this bug was filed to address.  In 8.4, the CLI allowed one to configure an etherchannel on the 4-port GigE module.  9.0/9.1 removed this capability in the CLI as the feature is not supported on the module.  Bug CSCtq62715 is the bug used to make this change.
Sincerely,
David.
Hi Gillian,
Sincerely,
David.
That makes sense David, thanks a mil for your response!
So I understand that the
So I understand that the 'channel-group' sub command has been depreciated. Am I correct in understanding that the use of
interface redundant 1
creates a redundant pair of interfaces and does not bond? If that's the case, what is the proper way to bond or LACP 2 interfaces in  9.1 and later?
I'm working on a 5520
415
