Community Member
CSCud43375 - AP crash on SNMP Engine on SNMP GET
                   Is this solved in 15.2.4-JB3a.tar ?
1 REPLY
Community Member
I'm pretty sure we have the
I'm pretty sure we have the same symptom after upgrading an AP1252 to 15.2(2)JA1.
The crashinfo file shows many tracebacks of the SNMP ENGINE being a CPUHOG, and finally the WATCHDOG process times out and down it goes.
The quick workaround was to turn off all SNMP processing via "no snmp-server" -- not a good solution.
So the 7.4 lightweight code has a fix but autonomous does not.  Any idea when that will be released?
183
