11-13-2013 02:35 PM - edited 03-20-2019 08:06 PM
Is there any timeframe of when this bug will be fixed? I have a customer that is wanting to know.
Solved! Go to Solution.
11-26-2013 04:32 AM
It is fixed on November 25th.
https://tools.cisco.com/bugsearch/bug/CSCuj51372/?reffering_site=dumpcr
11-26-2013 04:32 AM
11-26-2013 10:33 AM
Thank you sir!
12-10-2013 06:45 AM
you are welcome.. even the fixed version is released now..
02-09-2014 11:39 PM
We have 2 Cisco 3850 switches with stack , the IOS version is 03.02.01. we found that sometimes PCs cannot access other vlans but the same vlan is fine. After rebooting the 2 3850 switch. everything is working fine. we can make sure that there are no any virus and ARP attack in our network. Is it the same bug as this discussion. Thank you very much.
02-10-2014 05:00 AM
Hi Jerry,
it doesnt look like we are hitting the same bug. i might require more troubleshooting the stack when the isuse is happening to find what is causing the issue.
could you please check the behavior in 3.3.1 version? i am sure you might not face the issue in 3.3.1.
02-10-2014 09:06 AM
Thank you for your reply. I will try to upgrade IOS to 3.3.1.
