Community Member
CSCuj51372 - MacLearning not occuring for a group of 24 ports on 3850
Is there any timeframe of when this bug will be fixed? I have a customer that is wanting to know.
1 ACCEPTED SOLUTION
It is fixed on November 25th.
https://tools.cisco.com/bugsearch/bug/CSCuj51372/?reffering_site=dumpcr
Community Member
Thank you sir!
Community Member
We have 2 Cisco 3850 switches with stack , the IOS version is 03.02.01. we found that sometimes PCs cannot access other vlans but the same vlan is fine. After rebooting the 2 3850 switch. everything is working fine. we can make sure that there are no any virus and ARP attack in our network. Is it the same bug as this discussion. Thank you very much.
Hi Jerry,
it doesnt look like we are hitting the same bug. i might require more troubleshooting the stack when the isuse is happening to find what is causing the issue.
could you please check the behavior in 3.3.1 version? i am sure you might not face the issue in 3.3.1.
Community Member
Thank you for your reply.  I will try to upgrade IOS to 3.3.1.
1011
