fix for GNU bash vulnerability CSCur05454 in Instant Messaging & presence server available?
bug reports says 'Status: fixes' but I cannot find a patch for IM&P.
any information abaout that?
Juergen
Hi Juergen, This bug is fixed
Hi Juergen,
This bug is fixed in IM & Presence release 10.5(1.12900.2) i.e. 10.5(1)SU2 which you can download from Cisco.com software download site.
Vaijanath
Hi Vaijanath,Thanks - found
Hi Vaijanath,
Thanks - found IM & P 10.5(1)SU2.
Do you know if there are any updates, or updates coming, for similar fix in  CUCM & Unity Connection? I currently have  versions 10.5.1.10000-7 - which are "Known Affected Releases" for bug CSCur00930.
I can't find any of the "Known Fixed Releases" (shown below) on Cisco.com Software Downloads.
Known Fixed Releases:
(9)
10.5(1.11011.1)
10.5(1.11900.12)
10.5(1.98000.307)
10.5(1.98000.311)
10.5(1.98000.372)
10.5(1.98000.378)
Kind Regards
Gilbert
Hi Gilbert, Cisco has not yet
Hi Gilbert,
Cisco has not yet published the known fixed releases for download for CUCM and Unity Connection. A COP file,ciscocm.bashupgrade.cop.sgn, has been published on cisco.com that can be used to patch existing systems.
This file is available for download under Unified Communications Manager / CallManager / Cisco Unity Connection Utilities-COP-Files under download section.
Vaijanath
Vaijanath,Not really a direct
Vaijanath,
Not really a direct question for you but perhaps Cisco.
Apart from listing this COP file for download to patch existing systems, I'm wondering why Cisco don't list the  the 'ciscocm.bashupgrade.cop.sgn' patch as a fix or workaround in the associated Cisco Bug listing for CUCM (CSCur00930) and Unity Connection (CSCur05328)?  It's not even mentioned in either of the communications so it's not too clear that it is the "fix" or just an arbitrary patch to allay concerns of UC users.
Thanks again for you assistance and prompt response. Very much appreciated.
Kind Regards
Gilbert
No fix yet for earlier
No fix yet for earlier versions? I don't see anything for 8.6, for example.
The Readme document of the
The Readme document of the CUCM IM&P 10.5 Bash Environment Variable Patch.
http://software.cisco.com/download/release.html?mdfid=286269517&flowid=50462&softwareid=282074312&release=UTILS&relind=AVAILABLE&rellifecycle=&reltype=latest (registered users only)
states :
This package will install on the following System Versions:
  - 8.6.4.10000-28 or any higher version starting with 8.6.4.xxxxx
 - 8.6.5.10000-12 or any higher version starting with 8.6.5.xxxxx
 - 9.1.1.10000-8 or any higher version starting with 9.1.1.xxxxx
 - 10.0.1.10000-26 or any higher version starting with 10.0.1.xxxxx
 - 10.5.1.10000-9 or any higher version starting with 10.5.1.xxxxx
So the answer for you is : you should have at least/upgrade to 8.6.4.10000-28 and then apply the patch.
Regards.
391
