RJ45 Port on EHWIC-1GE-SFP-CU won't automatically connect after disconnection.
Hi, I am having trouble with the EHWIC-1GE-SFP-CU in a 1941 ISR router.
It works normally but after a cable disconnection, the interface needs to be bounced (shut / no shut) to get it to work. There seems to be a few bugs relating to this type of problem but no obvious fix.
Can you helps please.
FYI - System image file is "flash0:c1900-universalk9-mz.SPA.152-4.M4.bin"
interface GigabitEthernet0/0/0
bandwidth 6000
no ip address
ip flow ingress
load-interval 30
duplex full
speed 10
no cdp enable
service-policy output shape
end
thanks.
This forum is for the discussion of specific, numbered open bugs.  if you think you have a new bug, you will get better results if you ask on the relevant technology forum or open a TAC case.
Hall of Fame Super Gold
speed 10
Now I have never used the EHWIC before but are you certain the command to drop your SFP port to "10 Mbps" is necessary?  I mean you have a shapping policy in place already.
337
