Virtual Console connection - System refused connection
I have setup a few CSR 1000v routers on an ESXi 5.1 server
I have followed the instructions to enable the virtual serial port
I enabled the virtual serial port in the Firewall of esxi
However when I connect to the virtual serial port telnet://esxiip:2001
I get "The remote system refused the connection"
Do I need to configure anything on the router to make this work?
Roger
1 ACCEPTED SOLUTION
Roger,It depends on whether
Roger,
It depends on whether you've previously booted the CSR1000V.  If you did not select the serial console at the GRUB menu on the first boot you must configure platform console serial, save the config and reboot.  Here is a reference to the config guide:
http://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/csr1000Vswcfg/csrboot.html#pgfId-1307796
Hope that helps,
Nick
Roger,
Hope that helps,
Nick
Thanks Nick,I now configure
Thanks Nick,
I now configure the serial port and do not even open up the vmware console - working like a charm.
Roger
Roger,I agree.  I prefer
Roger,
I agree.  I prefer setting up the serial port and connecting to the device console directly rather than going through the vmware console.
-Nick
2050
