Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco 4500 series switch-Supervisor Engine.
Is it possible to add two different supervisor engine module in a chassis(WS-C4507R+E Chassis)? (WS-X45-SUP7E in slot 3 and WS-X45-SUP6E-
Redundancy in slot number 4)
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/RPR.html
Redundancy requires both supervisor engines in the  chassis to be of the same supervisor engine model (same model, same  memory, NFL daughter card and so on), and to use the same Cisco IOS  software image.
Hari.Sivaji
Hall of Fame Super Gold
No.  In redundancy mode, both supervisor has to be of the same model, running the same IOS with the same feature set.
1369
