Webcast-Catalyst9k
CSR1000V - Hang on startup
Not having much luck with CML and CSR1000V
The VM starts, but doesn't get to far.
msg log ..
  Booting 'CSR1000v - packages.conf'
root (hd0,0)
 Filesystem type is ext2fs, partition type 0x83
kernel /packages.conf rw quiet root=/dev/ram console= max_loop=64 VMCONSOLE HAR
DWARE=virtual SR_BOOT=bootflash:packages.conf
Calculating SHA-1 hash...done
SHA-1 hash:
        calculated   5363803a:48be4127:f333d659:c4b0a7c0:cc5a66bf
        expected     5363803a:48be4127:f333d659:c4b0a7c0:cc5a66bf
package header rev 1 structure detected
SHA-1 hash:
        calculated   7cc4bb:3a9c390a:17abab66:8e7e4d65:d3728ee
        expected     7cc4bb:3a9c390a:17abab66:8e7e4d65:d3728ee
Package type:0x7531, flags:0x0
   [Linux-bzImage, setup=0x2e00, size=0xe77c920]
   [isord @ 0x72e0c000, 0xd1e3000 bytes]
%IOSXEBOOT-4-NET-SMP-AFFINITY: (local/local): set smp affinity for 27
%IOSXEBOOT-4-NET-SMP-AFFINITY: (local/local): set smp affinity for 28
%IOSXEBOOT-4-NET-SMP-AFFINITY: (local/local): set smp affinity for 26
These are qcow images from CCO.   Should I use some other image type?
The OVA image works fine if boot it on esxi
Hello,Thanks for posting the
Thanks for posting the issue.
Please let us know below query:
Where you have downloaded the image?
Whether you have deployed the OVA on ESXi or playing through VM Player, please confirm where exactly you are facing the issue.
Thanks and Regards,
Bikash
They are from CCO csr1000v
They are from CCO
csr1000v-universalk9.03.13.00a.S.154-3.S0a-ext.qcow2
csr1000v-universalk9.03.12.00.S.154-2.S-std.qcow2
I imported both into CML and they are available within the user giu.
Test case is simple .. create a single router topology and then start it in simulation.
However, the CSR router will not boot. ..hangs as per my original post.
I have not tried importing CSR1000V OVA images into CML.
My OVA comment was related to using them on ESXI ,, sorry for the confusion
Hello,Thanks for your update,
Thanks for your update, please raise a TAC case for this issue
Thanks and Regards,
Bikash
464
