Multiple FLAT interfaces (dot1q) on CML?
Hi I would like to connect CML to a traffic generator simulating PEs through one physical interface on the Hypervisor using Vlan. But during the installation of CML (settings.ini) I don't see any option in order to setup multiple FLAT networks.
Any idea if it is supported?
Many thanks!
Youssef
1 ACCEPTED SOLUTION
Hello Youssef,Yes, you are
Hello Youssef,
Yes, you are correct..
Thanks & Regards,
Vidyasagar.
Youssef, Thanks for the
Youssef,
Thanks for the question!  We'll have someone check into that and someone will post an answer as soon as we have something to share.
DavidM
still be nice to have
still be nice to have multiple flats without vlans.
Hi You can specify multiple
Hi You can specify multiple interfaces and VLANs are part of the setup -
See page 21 – Step 12 – of the Install Guide (http://www.cisco.com/c/en/us/td/docs/cloud_services/cisco_modeling_labs/v100/installation/guide/administrator/b_cml_install_sys_admin.html)
Hi, so I can repeat Step 12
Hi, so I can repeat Step 12 and finally have more than one FLAT network, it will be taken in account in the settings.ini file of CML?
Am I correct?
Thanks!
Youssef
Hello Youssef,
Thanks & Regards,
Vidyasagar.
307
