CISCO 881 how exactly identify IOS for installation.
Dear All.
Please clerify for me:
1.I have a cisco router CISCO881-SEC-K9.
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
if I understood it correctly - 12.4(22r)YB5 - is my current IOS version.
2.I would like update my IOS and save all licenses which already installed.
Questions:
1.How  how exactly identify IOS for installation, which release?
2.How to make installation and save installed licenses.
   any examples?
1 ACCEPTED SOLUTION
The ServiceGrid Community is
The ServiceGrid Community is specifically for software enabled services and unfortunately we can not answer this questions.
However, you can raise your question in the lan switches and routing community:
https://supportforums.cisco.com/community/6016/lan-switching-and-routing
I hope that helps
best regards
Patrick
I hope that helps
best regards
Patrick
Ok, done!Thank You.Best
Ok, done!
Thank You.
Best Regards.
264
