07-03-2017 02:34 AM - edited 03-01-2019 02:36 AM
Hi everyone.....
I have two sets of 8 Cisco 2960XR switches stacked together. I need to cascade these two stacks through Fiber ports.
Is it possible???
Gaurav
07-03-2017 04:42 AM
Sure you can link two stacks together but this will depend on the use of SFP or SFP+ modules and the quantity per stack.
07-03-2017 04:45 AM
Thanks mate:)
Appreciate!!!!
05-29-2018 08:34 PM
Yes stacking switches with FlexStack-Extended Fiber modules that are deployed across different floors of a building. The SFP+ module ports are connected using fiber cables.
Using FlexStack-Extended Hybrid module, you can combine existing stack of switches and new switches spread across multiple wiring closets into one single stack. To achieve this, the copper port on the FlexStack-Extended Hybrid module should be connected to the FlexStack-Plus port on a switch in your existing network. The fiber port on the Cisco FlexStack-Extended Fiber module can be used to connect switches over long distances. You can stack up to eight switches.
