Cisco Jabber Voice problem with Android KITKAT 4.4.2
I am facing a problem with my Galaxy S4 running Android 4.4.2 when using Cisco Jabber Voice v 9.1(5) I am only able to use it when connected vua our corporate WIFI, but when using Jabber via 3G and VPN the communication is only 1 way: the called party can hear me, but I can't hear anything. Is there any solution for this problem?
1 REPLY
Hello, Jean !!I was faced
Hello, Jean !!
I was faced same problem with Galaxy S4 and Galaxy S3 using Cisco Jabber Voice on VPN Connection and solved it 2 weeks ago.
I suggest that you have to check a firewall running VPN and disable the inspection of voice protocol such as "inspect h322 h225, inspect h323 ras, inspect sip, and inspect skinny" if you are using Cisco ASA Firewall.
Hank.
511
