Bronze
ATA187, SIP trunks, CUBE
What dial-peer fax statements would be advised in a case where the ITSP (SIP Trunking) only supports g711a pass though for fax?
We are having a hard time making outbound faxes work reliably from a ATA187.
How much 'relay' can/should the gateway do in this case (to my understanding there is no 'relay' in this case)?
Should we rely solely on the ATA187 configuration in CUCM and the settings on the fax machine ? (Speed, ECM, etc)
Gateway/CUBE 15.3, CUCM 9.1.1a
Erik
The following is an example config you can make use of with an SIP enviroment.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol pass-through g711alaw
h323
modem passthrough nse codec g711alaw
sip
  registrar server expires max 3600 min 3600
  asserted-id pai
  privacy pstn
  options-ping 60
  midcall-signaling passthru
dial-peer voice 200 voip
description -----  WYCHODZACE SIP-T ------
destination-pattern [1-9]........
session protocol sipv2
session target ipv4:SIP-SRV:5020
voice-class codec 23
voice-class sip dtmf-relay force rtp-nte
voice-class sip early-offer forced
voice-class sip pass-thru headers unsupp
voice-class sip pass-thru content unsupp
voice-class sip pass-thru content sdp
dtmf-relay rtp-nte
req-qos controlled-load audio
fax-relay ecm disable
no vad
dial-peer voice 101 voip
description **Outgoing Call to CUCM**
destination-pattern 895216...
session target ipv4:CCM1
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
Voice CCIE #37771
Re:ATA187, SIP trunks, CUBE
The ATA-187 does support pass through on a specific firmware of the ATA, that would 9.2.3.1 supports both T.38 and modem pass through.
https://supportforums.cisco.com/thread/2189681
Hope this link helps.
Kevin
Sent from Cisco Technical Support Android App
1755
